I am having problems trying to read a tag set from a DGN file. The 'title' view in the model holds some file metadata in 62 tags that I need to extract and potentially inlcude as attributes as part of a CAD to GIS translation. The 62 tags appear to be associated with a level that holds a single text element, but when I read the model I can't detect the tags. Any help on how I should be configuring the reader would be appreciated. But also confirmation of if the DGN model is correctly structured would also be good. I have attached a screenshot of the tag properties from the DGN model.
