kmlpropertysetter: I want to add hyperlinks to my kml popup up balloon.
  • June 19, 2018
  • 80 views
jhawks
Forum|alt.badge.img+7
I only need certain records to have hyperlinks. See attached image, (created with arc2earth). I'm trying to create the same popup with a workbench, see attached.
noaa-rncs-shape-kml.fmw
I think you can use AttributeManager to wrap the URL in an href tag something like:
<a href="https://www.safe.com">link</a>
or for an attribute it would look like:
<a href="@Value(DWNLD_URL)">link</a>
jhawks
  • June 22, 2018
Still having trouble, not sure which part of the formatting I should do in kmlproperty setter vs attribute manager. If I include the attributes in kmlproperty setter I can do any formatting in attribute manager. (i think). Ultimately I want my popup balloon to look like the attached one, no grey line on every other record, and then hyperlnks on certain records.
