Objs aren't in the right position in b3dm
  • May 9, 2018
  • 21 replies
  • 102 views
Firstly I combined my building objs by Aggregator, then I separated them by Deaggregator, finally to b3dm. I have coordinates of those building objs but All building overlapped in Cesium, How can i locate the buildings according to coordinates.
Best answer by daveatsafe
Hi @safa833,
Please try the attached workspace, which merges the CSV and the OBJ with the FeatureMerger, then uses the LocalCoordinateSystemSetter to georeference the models.
obj2cesium3dtiles.fmw
daveatsafe
Forum|alt.badge.img+20
  • May 10, 2018
Hi @safa833,
In order to use the CSV coordinates with the objects, you will need to merge the coordinate attributes onto the objects with a FeatureMerger transformer, then use an Offsetter transformer to apply the coordinates.
If you would like to share your workspace, I would be happy to modify it to show how to do this.
  • May 11, 2018
Hi @safa833,
I'll appreciate for your helping very much, Thanks.
Also I have a trouble related to coodinates system
Link: myproj.rar
daveatsafe
  • May 11, 2018
Hi @safa833,
  • May 11, 2018
Hi @safa833,
First of all, I am much obliged for your helping
When I put to my project output of the workspace that you sent, Elevation problem appears:
After setting 3D Tiles Writer to LL84:
In this case I want to ask two questions
1. How Can I enter elevation value in csv file into each obj
2. Or How Can I provide objs to stick according to terrain elevation
daveatsafe
  • May 14, 2018
Hi @safa833,
You can use an Offsetter transformer to move the models to the elevation supplied in the CSV.
However, Cesium automatically drapes the model to the ground elevation, so you want to set the bottom of the model to 0 elevation. I am attaching a workspace illustrating how to get the bottom of the model's elevation, then use an Offsetter to move this to 0.
obj2cesium3dtiles-2.fmw
  • May 14, 2018
Hi @safa833,
Hi, @DaveAtSafe
Using Offsetter had come to my mind too. However, Nevertheless I thought that discussing is better. Thank you.
Finally, Another problem I come across is that texturing and transparancy.
Textures is not outside of objs, is inside of them and I can see inside buildings.
I carried out a set of regulations with AppearanceSetter but I could not obtain result I wanted.
daveatsafe
  • May 14, 2018
Hi, @DaveAtSafe
Hi @safa833,
I added an Orientor to reverse the surface orientation, to fix the textures.
obj2cesium3dtiles-3.fmw
  • May 15, 2018
Hi @safa833,
Hi, @DaveAtSafe Thank you for sharing.
In order to troubleshoot transparancy issue, When I set alpha value of AppearanceSetter to 1.0, Textures disappear. How to fix this issue.
For Example:
daveatsafe
  • May 15, 2018
For Example:
Hi @safa833,
The AppearanceSetter will create a new appearance on the surface, removing the original.
To modify the original appearances, we must extract them from the surfaces, change the alpha value, then replace them.
FME stores appearances in a library. The SharedItemRetriever can be used to extract the texture images from that library. After modifying the Alpha, we can replace the texture images using the SharedItemAdder in update mode.
I am attaching an updated workspace to illustrate.
obj2cesium3dtiles-4.fmw
  • May 16, 2018
Hi @safa833,
Hi @DaveAtSafe
There is a GeometryFilter in the workspace. I don't understand completely what does it do. Can you explain it ?
daveatsafe
  • May 16, 2018
Hi @DaveAtSafe
Hi @safa833,
Sure. I send both the 3D objects and the texture rasters into the FeatureHolder, to make sure that nothing is written to the output file before the texture library is updated. However, we don't want to write the raster features to Cesium, just the 3D objects. So I use a GeometryFilter to filter out the rasters.
  • May 18, 2018
Hi @DaveAtSafe
Hi @DaveAtSafe,
Thanks a lot Dave, you answered my questions patiently, Thanks a lot again.
  • May 24, 2018
Hi @DaveAtSafe,
There is an issue pertaining to dark of objs.
In your opinion, How Do I need to perform an alteration in the workspace?
1. Output of the workspace:
2. Output after converting each obj to glTF through https://github.com/AnalyticalGraphicsInc/obj2gltf
  • May 25, 2018
Hi @DaveAtSafe,
It seems like resulting from pbrMetallicRoughness.
  • May 27, 2018
Hi @DaveAtSafe,
Obj reader doesn't support illum parameter in mtl file.
Output: OBJ Reader: Token Unsupported: 'illum' - Ignored
Which transformer do i need to use for it?
daveatsafe
  • May 28, 2018
Hi @DaveAtSafe,
Hi @safa833,
I'm sorry, but FME does not currently support illumination models. I'm not sure they would be needed, since Cesium uses a sun based lighting model.
  • September 17, 2018
Hi @DaveAtSafe,
In order to increase performance of 3D Tiles, Textures of Objs need to be combined, I mean texture atlas.
For example :
How can the process be done in FME?
Thanks in advance
daveatsafe
  • September 20, 2018
Hi @DaveAtSafe,
For example :
Thanks in advance
Hi @safa833,
I'm sorry, but creating a texture atlas is not presently something that can be done in FME. We are looking into adding this capability in the future, and I will notify you when it becomes available in beta.
  • September 21, 2018
Hi @safa833,
Thanks @DaveAtSafe,
I'm waiting for the feature impatiently
  • October 19, 2018
Hi @safa833,
Hi @DaveAtSafe,
Hopefully, I have tried Cesium 3D Tiles Writer in FME Desktop 2019.0 Beta build: 19133 for texture atlas but This capability hasn't yet added FME. When does it become available in FME? Thanks.
charry
Forum|alt.badge.img+5
  • December 18, 2024
Hi @DaveAtSafe,
For example :
Thanks in advance
Hi @safa833,
Has the texture atlas feature been added?
