Preserve Global ID Error
Hi
I am importing Points along with their attachments from ArcGIS Online. I am using sde writer with the new option of preserving GlobalIDs. the issue is it runs smoothly on feature class but with table initially it runs fine and stores the data but at the end it gives me this error.
  • October 16, 2019
Anyone with answer?
sigtill
Forum|alt.badge.img+24
  • November 5, 2019
Hi @smas1
Try to run again and turn on all the Log Messaging in FME Options to see if you get more information
FME 2020.2 has already fixed this problem, it works with geodatabase tables as well
