Syntax for FeatureReader - Smallworld
I am having trouble getting the syntax right for the FeatureReader using Smallworld.
A small example: I would like to read all pipe segments that have certain status and a certain material (which could have been taken from an XML file, for example - here, for simplicity, I created the attributes with an AttributeCreator).
I have tried every variation with and without quotiation marks, but cannot get it to run. I am using FME 2013 (upgrading is not an option, as it's not in my power) and the SpatialBiz plugin to access Smallworld.
itay
Forum|alt.badge.img+17
  • May 9, 2017
@erik_jan, something you can help with?
erik_jan
Forum|alt.badge.img+18
  • May 11, 2017
The first question is: what SmallWorld reader are you using? The built in Smallworld (GE) reader or the Spatialbiz plugin for SmallWorld?
  • May 11, 2017
Spatialbiz Plugin for Smallworld. I'm adding that to the question, should have been there in the first place.
erik_jan
  • May 11, 2017
Have you tried the WHERE clause: status = '@Value(status)' ?
That works for feature types in the Spatialbiz plugin reader.
  • May 11, 2017
I am at my home computer right now, so I can't confirm - but I am quite sure I did. Curiously, what did work is "where status='Existing' ", i.e. if I didn't use a variable.
Also what I was not able to do was a combination of two statements, such as "where status='Existing' and material='Steel'.
  • May 12, 2017
I fear this does not work: While the syntax seems to be accepted, the numbers are completely off (FME returns about 28000 entries, while SW states 92000 entries).
I fear this might be an SpatialBiz-Bug: I removed the where-clause altogether and the problem remained. I felt that was worth an own question: Bug in FeatureReader
erik_jan
  • May 12, 2017
Please supply the workspace and the log to support@spatialbiz.com and I or one of my colleagues will have a look.
  • May 12, 2017
Thanks! I have sent the workbench.
