I am trying to write to a file geodatabase and I need the strings stored as 8 bit characters. When I write to the gdb they being written as utf-16.
I have tried using the attribute encoder to set the encoding to utf-8 but it still get written as utf-16. I am using a feature writer with the DEFAULTS keyword which should store text as utf-8 according to the documentation. Is there a way to enforce that text data be written as UTF8.
Thanks
