Hi all,
I've got a workbench where I'm trying to convert a series of dgns to a geodatabase. I have used the tester to filter out the colour white (which is the title block, the dgns are 20 years old) and then I've used a geometry filter to filter by 'area' so that I only get the polygons I need. The inspector gives me exactly what I want except that I now need to made the 'fme_color(string)' an attribute, for example I would like green (0,1,0) to be freehold in my geodatabase attribute table. Can anybody help me out? Thanks
