Convert lat/lng to geom data type
  • June 19, 2017
  • 214 views
I have to convert these lat/lng to geom data type, such these lat/lng are in space (here I have done wrong), Kindly guide how I can convert them (lat,lng) to geometry such that they occur in space. Thank you
Best answer by redgeographics
You can use a VertexCreator to create geometry from the lat and lng attributes, or the GeometryReplacer to use the geom attribute, it looks like that's in OGC WKT format.
Hope this helps.
Forum|alt.badge.img+62
  • June 19, 2017
Hope this helps.
mark2atsafe
Forum|alt.badge.img+59
Yes, I suggest the VertexCreator transformer as Hans suggests. I made a short movie of the process that you can access here:
https://www.screencast.com/t/nFhuUqdh1tvM
mark2atsafe
You can also find examples on the knowledge centre - for example here converting CSV to Shape: https://knowledge.safe.com/content/kbentry/1493/index.html
