Hi
This is a problem which has bugged me for years. I cannot work out how to set the feature type as a published parameter in a FeatureReader transformer that is reading in a Microstation DGN file. I have a number of different combinations of the following settings and none seem to work. All I get is one record coming out of the Initiator Port and the DGN file data does not come out of any of the ports.
Can anyone help me with this?
I am on FME Desktop 2019.1.
Thanks!
