How to create fillet between 2 polylines
  • November 24, 2017
  • 15 replies
  • 232 views
hi,
I'd like to create a fillet (like the autocad command) between 2 polylines ? is-it possible?
desired is the red arcs.
thanks
danilo_fme
Forum|alt.badge.img+52
  • November 24, 2017
Hi @miladahmad,
Has a similar question resolved here Lines to Arcs.
Thanks,
Danilo
  • November 24, 2017
Hi @miladahmad,
Thanks,
Danilo
Hi @danilo_inovacao, thanks for finding that.
It's an old thread, and I removed all the shared workspaces from my Google Drive at some point in the last year...
Now I've restored that with FME 2017. Hope this helps.
create-arc-between-adjoining-lines.fmw (FME 2017.0.1.1)
danilo_fme
  • November 24, 2017
Great @takashi,
I believe your Workspace is perfect to solve his problem :)
Thanks,
Danilo
  • November 24, 2017
thank you (@danilo_inovacao and @takashi). I already saw the question but the workspace was not available. I will try it but I’m afraid that workspace will do the fillet at all corner of polylines. What I want is doing that only for the intersection of 2 polylines (example: I will used to create the intersection of roads). I will test it.
  • November 24, 2017
Hi @miladahmad, I think you can apply the fundamental logic in my Python script to create an arc between two adjacent lines. The point would be how to specify the lines around an intersection of roads. Are there some conditions that you can use to specify them?
  • November 24, 2017
The workspace do it between all vertics of polyline. I will try to explain what I'm trying to create with the image (is better than my english :) ). PS. I have the roads center lines and the polygons (or I can also do offset to the centerline)
And the desired area or arc at the corner
thanks
  • November 24, 2017
do we neeed to specify lines around intersection if i want to do fillet at all intersection between 2 lines?
  • November 24, 2017
thanks
The result from this workspace might be closer to your requirement.
create-arc-between-adjoining-lines-2.fmw (FME 2017.0.1.1)
  • November 24, 2017
thanks @takashi : It is great but it works only if I have 2 intersected lines (2 and 3 or 1 and 3). If roads which I have is segmented at the intersection (I have 3 lines), then I got error from python caller (Error encountered while calling method `input' f_75(PythonFactory): PythonFactory failed to process feature). I think a problem with list Index.
  • November 25, 2017
The Python script should work if the input feature has a polyline consisting of enough long two segments. I can only provide how to create an arc between adjacent two line segments.
As I mentioned before, it would be the point of this subject how you can extract a proper line consisting of two segments around an intersection. However, it's hard to provide an ideal way to do that, since it could be different depending on the actual data conditions.
If you could share the actual source data (road center lines?) here, a good idea might be provided.
  • November 25, 2017
road-intersection.zip
this is a small example of data. There is a roads intersection between 2 polylines, 3 polylines and 4 polylines.
  • November 26, 2017
I just added two transformers - CoordinateCounter and Tester to the previous workspace example in order to avoid the error in the case where two road center lines on the almost same straight line are connected at an intersection. See the attachment.
create-arc-between-adjoining-lines-3.fmwt (FME 2017.0.1.1)
  • November 26, 2017
it is really great. thanks a lot for your time and your help (I do not know if it is difficult to adjust it to have one more arc as the image)
have a nice week-end and thanks again (i did not find where I can accept the workspace as answer)
  • November 27, 2017
I think this workspace example contains some tips, which would help you to find a proper solution.
create-arc-between-adjoining-lines-4.fmwt (FME 2017.0.1.1)
  • November 27, 2017
100% useful and what I want.
Thanks a lot and best regards.
