Is it possible to spatially filter a LAS file using a 3d object?
I have created a multipatch 3d AOI in ArcGIS expecting to be able to do 3d spatial analysis with it, but appears that LAS datasets cannot be used with the 3d Analyst extension - Inside 3d tool.
Is this possible in FME? I have tried spatial relator but that does not seem to achieve what I am after.
