Extract folder / subfolder name KML
  • September 4, 2017
  • 84 views
danilo_fme
Forum|alt.badge.img+52
Hello,
I have a kmz file and i would like to extract the name folder - Attached.
Thanks, -
Danilo
Best answer by takashi
Read the kmz dataset with the KML reader and see the "kml_name" attribute of the Folder feature.
  • September 5, 2017
geosander
Forum|alt.badge.img+7
  • September 5, 2017
Yes, that's right! And then use a FeatureMerger to join by the kml_parent_id attribute (on the Placemark feature) and kml_id (on the Folder feature) if I'm not mistaken.
danilo_fme
  • September 5, 2017
Hi @takashi, i appreciate your help. Thanks!
danilo_fme
  • September 5, 2017
Hi @sander_s, thanks your answer. I'll use the FeatureMerger to join... Thanks one more time.
