Hello,
I am transforming Ordnance Survey MasterMap data into an ESRI Geodatabase. Where I require assistance is with the cartographic text (labelling) layer. This layer provides labeling information including font, colour, rotation and placement. I can't use these attributes directly in ArcMap or ArcGIS Pro which leads to labels overlapping and looking generally messy. I have found that writing these attributes to the relevant format attributes in the geodatbase writer work well but it is increadibly slow and discoraged by Safe. I am seeking advice or an alternative.
Many Thanks
David
