Sending/Receiving notifications in FME Server 2013
  • October 25, 2013
  • 15 views
Hi all,
I need some help with sending receiving success/fail notifications with FME Server 2013.  I've read all I can find online but it only really covers FME Server 2012.  Are there any good documents out there that are for FME Server 2013?
Here are a few of my questions:
When I publish a workspace to FME Server under the Job Submitter service I select the success and fail topic to publish (Is this where my success/fail notification will go?), the I have the option to select a Notification Writer.  Do I have to create this writer and all the content of the notification writer in my workbench?
Thanks
Rob
  • October 25, 2013
Hi Rob,
you can find a lot of informations in the KnowledgeBase or in the FMEServerDocumantation.
The Notification Wirter you can use, if you want create a dinamic message. If you want always the same message, you define it directly in the EmailTemplate of the subscription.
Thomas
