Sharepoint issues 401
  • April 3, 2018
  • 11 replies
  • 55 views
gboquin
Forum|alt.badge.img+8
I am having issues connecting to a sharepoint site. I get an error 401-- Client access error.
I confirmed having access via manually reviewing the site. Any pointers? or ways to trouble shoot?
I am using FME 2016 or FME 2017
Thanks in advanced.
lars_de_vries
Forum|alt.badge.img+10
There were issues with the Sharepoint Online list reader. It should be solved in FME2017.1.2.1 and in FME2018
gboquin
  • April 4, 2018
Thank you. I will have to wait to upgrade FME server before I can try it out.
carsonlam
Forum|alt.badge.img+7
  • April 6, 2018
SharePoint Online's authentication changed again recently, which broke how our reader and writer authenticated with it. We've made a fix in FME 2018.0 18291+ and FME 2018.1 betas 18449+.
gboquin
  • August 23, 2018
Do you guys know if the authentication changed again? I just installed
FME(R) 2018.1.0.1 (20180730 - Build 18528 - WIN64 and have manual access but not via FME. Thoughts?
Same here,cant for the life of me get it to log in, worked not that long ago. 2018.1.0.3 (20180926 - Build 18552 - WIN64)
  • March 25, 2019
2018.01 version still has this issue
andreaatsafe
Forum|alt.badge.img+15
Hi @jrogers,
Sorry to hear you are encountering an issue with accessing Sharepoint data. To help us debug the issue, we need some further information:
  • Please share the full log file with the error message you are receiving
  • What version of Sharepoint are you connecting to?
  • What is the authentication method you are using? Do you have any proxy settings?
  • March 26, 2019
Sharepoint Office 365 2013
  • March 26, 2019
Creating reader for format: Microsoft SharePoint List
Trying to find a PYTHON plugin for reader named `SHAREPOINT'
Using Python interpreter from `C:\\Program Files\\FME\\fmepython27\\python27.dll' with PYTHONHOME `C:\\Program Files\\FME\\fmepython27'
Python version 2.7 loaded successfully
Loaded Python module `sharepoint' from file `C:\\Program Files\\FME\\plugins/python27\\sharepoint\\__init__.pyc'
Microsoft SharePoint List Reader: Items Per Request format parameter is set to '5000'
Microsoft SharePoint List Reader: Using proxy http://amrbasic-proxy.bp.com:80/
Microsoft SharePoint List Reader: Logging into 'https://bp365.sharepoint.com/sites/RMO' as '' using authentication mode 'SAML'
Microsoft SharePoint List Reader: Client-side error: '403 Client Error: Forbidden for url: https://bp365.sharepoint.com/sites/RMO/_api/web/Lists?%24select=Title%2CId' returned from SharePoint. Error message was: 'Access denied. You do not have permission to perform this action or access this resource.'
Failed to obtain any schemas from reader 'SHAREPOINT' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
UniversalReader -- readSchema resulted in 0 schema features being returned
Reader Parameter(0) = >https://bp365.sharepoint.com/sites/RMO<
Reader Parameter(1) = >USER<
Reader Parameter(2) = ><
Reader Parameter(3) = >PASSWORD<
Reader Parameter(4) = >********<
Reader Parameter(5) = >AUTHENTICATION<
Reader Parameter(6) = >SAML<
Reader Parameter(7) = >HIDDEN_LISTS<
Reader Parameter(8) = >Yes<
Reader Parameter(9) = >ALL_FIELDS<
Reader Parameter(10) = >Yes<
Reader Parameter(11) = >_MERGE_SCHEMAS<
Reader Parameter(12) = >YES<
Reader Parameter(13) = >RETRIEVE_ALL_TABLE_NAMES<
Reader Parameter(14) = >YES<
Reader Directive(0) = >RUNTIME_MACROS<
Reader Directive(1) = >USER,,PASSWORD,********,AUTHENTICATION,SAML,HIDDEN_LISTS,Yes,ALL_FIELDS,Yes,_MERGE_SCHEMAS,YES,RETRIEVE_ALL_TABLE_NAMES,YES<
Configuration object contents:
FME Temporary Folder: C:\\Users\\roj72w\\AppData\\Local\\Temp
mapping file Line 0: `APPLICATION' `FME_WORKBENCH'
mapping file Line 1: `AUTOREG' `YES'
mapping file Line 2: `LOG_ENCODING' `UTF-8'
mapping file Line 3: `LOG_MAX_FEATURES' `-1'
mapping file Line 4: `LOG_APPEND' `NO'
mapping file Line 5: `FME_HOME' `C:\\Program Files\\FME\\'
mapping file Line 6: `FME_SESSION_USED' `TRUE'
mapping file Line 7: `R_1_METAFILE' `SHAREPOINT'
mapping file Line 8: `R_1_DATASET' `https://bp365.sharepoint.com/sites/RMO'
mapping file Line 9: `R_1_USER' `'
mapping file Line 10: `R_1_AUTHENTICATION' `SAML'
mapping file Line 11: `R_1_HIDDEN_LISTS' `Yes'
mapping file Line 12: `R_1_ALL_FIELDS' `Yes'
mapping file Line 13: `R_1__MERGE_SCHEMAS' `YES'
mapping file Line 14: `R_1_RETRIEVE_ALL_TABLE_NAMES' `YES'
mapping file Line 15: `R_1_USER' `'
mapping file Line 16: `R_1_AUTHENTICATION' `SAML'
mapping file Line 17: `R_1_HIDDEN_LISTS' `Yes'
mapping file Line 18: `R_1_ALL_FIELDS' `Yes'
mapping file Line 19: `R_1__MERGE_SCHEMAS' `YES'
mapping file Line 20: `R_1_MERGE_SCHEMAS' `YES'
mapping file Line 21: `R_1_RETRIEVE_ALL_TABLE_NAMES' `YES'
mapping file Line 22: `SCHEMA_TIME' `YES'
mapping file Keyword: `LOG_ENCODING' occurs 1 time(s)
mapping file Keyword: `R_1__MERGE_SCHEMAS' occurs 2 time(s)
mapping file Keyword: `FME_SESSION_USED' occurs 1 time(s)
mapping file Keyword: `R_1_ALL_FIELDS' occurs 2 time(s)
mapping file Keyword: `LOG_APPEND' occurs 1 time(s)
mapping file Keyword: `R_1_RETRIEVE_ALL_TABLE_NAMES' occurs 2 time(s)
mapping file Keyword: `R_1_AUTHENTICATION' occurs 2 time(s)
mapping file Keyword: `R_1_DATASET' occurs 1 time(s)
mapping file Keyword: `SCHEMA_TIME' occurs 1 time(s)
mapping file Keyword: `R_1_PASSWORD' occurs 2 time(s)
mapping file Keyword: `R_1_METAFILE' occurs 1 time(s)
mapping file Keyword: `FME_HOME' occurs 1 time(s)
mapping file Keyword: `R_1_HIDDEN_LISTS' occurs 2 time(s)
mapping file Keyword: `R_1_USER' occurs 2 time(s)
mapping file Keyword: `AUTOREG' occurs 1 time(s)
mapping file Keyword: `LOG_MAX_FEATURES' occurs 1 time(s)
mapping file Keyword: `R_1_MERGE_SCHEMAS' occurs 1 time(s)
mapping file Keyword: `APPLICATION' occurs 1 time(s)
andreaatsafe
Thanks for sharing the log file @jrogers. Can you confirm what kind of authentication your sharepoint uses? Does it use active directory federated services? You may need to check with your IT team at your organization.
  • March 28, 2019
Our Sharepoint folks say
We’re using the O365 Organizational authentication…
Is there something more specific that you need?
Justin
