ECW reader: Failed to retrieve data from the source dataset
brandonguo
Forum|alt.badge.img+3
Fail when converting ecw file. Got error message after
FFS writer: Completed 100% of intermediate processing
____________________________________________________________
FFS writer: Completed 0.18% of intermediate processing
... Last line repeated 3 times ...
Stored 1 feature(s) to FME feature store file `J:\\FME_TEMP\\wb-cache--PNXtVL\\Main_EsriReprojector -1 3 fo 0 REPROJECTED 0 66d791aea5c163f33c7ab04cb5e7a95a424ee21e.ffsupdating'
Saving spatial index into file 'J:\\FME_TEMP\\wb-cache--PNXtVL\\Main_EsriReprojector -1 3 fo 0 REPROJECTED 0 66d791aea5c163f33c7ab04cb5e7a95a424ee21e.fsi'
Finished saving spatial index into file 'J:\\FME_TEMP\\wb-cache--PNXtVL\\Main_EsriReprojector -1 3 fo 0 REPROJECTED 0 66d791aea5c163f33c7ab04cb5e7a95a424ee21e.fsi'
EsriReprojector_REPROJECTED Feature Recorder -1 2147614723 (RecorderFactory): Failed to write feature data to `J:\\FME_TEMP\\wb-cache--PNXtVL\\Main_EsriReprojector -1 3 fo 0 REPROJECTED 0 66d791aea5c163f33c7ab04cb5e7a95a424ee21e.ffsupdating'
Stored 1 feature(s) to FME feature store file `J:\\FME_TEMP\\wb-cache--PNXtVL\\Main_ECW -1 2 -1 0 d50a83ef1c0a9074bd918f5edfdf9b1df3368482.ffsupdating'
Saving spatial index into file 'J:\\FME_TEMP\\wb-cache--PNXtVL\\Main_ECW -1 2 -1 0 d50a83ef1c0a9074bd918f5edfdf9b1df3368482.fsi'
Finished saving spatial index into file 'J:\\FME_TEMP\\wb-cache--PNXtVL\\Main_ECW -1 2 -1 0 d50a83ef1c0a9074bd918f5edfdf9b1df3368482.fsi'
Translation FAILED with 3 error(s) and 2 warning(s) (0 feature(s) output)
FME Session Duration: 4 hours 0 minutes 27.3 seconds. (CPU: 4154.5s user, 1464.0s system)
END - ProcessID: 24324, peak process memory usage: 7717316 kB, current process memory usage: 263260 kB
Program Terminating
Translation FAILED.
Best answer by rahulsharma
Hi @brandonguo
What is the size of ECW files you are trying to load?
Can you confirm if you have FeatureCaching ON or OFF? If it is ON, go to Run (Drop-down menu) --> "Enable-Feature Caching" uncheck the option and re-run the workspace.
Can you explain your current workflow?
Are you running a 32bit or 64bit version of FME Desktop?
rahulsharma
Forum|alt.badge.img+10
  • March 13, 2020
Hi @brandonguo
brandonguo
  • March 15, 2020
rahulsharma wrote:
Hi @brandonguo
Hi @rahulsharma
Feature Caching is on at the moment, I'll turn it off see how it goes. Currently running 64bit and the ECW size is about 13GB.
Thanks.
daraghatsafe
brandonguo wrote:
Hi @rahulsharma
Thanks.
Hi @brandonguo, were you able to test the workspace with the Feature Caching turned off?
brandonguo
  • March 19, 2020
Sure, currently running at 9.81% without errors, good sign~
daraghatsafe
Good to hear, let us know if you are successful.
brandonguo
  • April 19, 2020
Works after turn off the feature caching. Thanks.
