This is the first time I'm attempting to write to an SDE database, and I'm encountering some hiccups.
1. If I use an SDE30 connection, everything works 100% according to the workspace, and despite it displaying that all 33079 my point features succesfully go to the writer (with the translation successful message) there is nothing in the database when I check in ArcCatalogue/Map. The feature class is not even created, never mind blank.
2. If I use GEODATABASE_SDE writer, I get the following error in FME, which also fails the translation:
Unable to create the table/feature class TUN_MN_TEST. When writing to a pre-9.2 Enterprise Geodatabase, a value of 0 is not appropriate for the GEODB_XYSCALE. Specify a number greater than 0
What makes this case even stranger, is that I got option 2 to work once. Without changing a single thing. It actually created the feature class and everything seemed fine, and when I tried to run it again (without changing anything at all) it gave the error again...
Any help would be awesome.
Regards,
