Can I control DPI when I convert a pdf to a tiff?
  • November 29, 2018
  • 61 views
Hello,
I have a simple workspace that renames and exports pdf documents to tiffs. Its the PDF2D reader, some renaming transformer,s and the TIFF writer. The tiffs need to be 400 dpi. No matter what I do, I only get 96 dpi. Is there a way to control this?
I have been able to get the 400 dpi using other software, but it's either clunky or will cost me more money. FME is obviously the preferred method if I can fulfill this one requirement.
I appreciate any help.
Thank You,
FME(R) 2018.1.0.1 (20180730 - Build 18528 - WIN64)
gio
Forum|alt.badge.img+15
  • November 30, 2018
@justinv
you can just calculate the amount of pixels required and use it as input for number of columns/rows
400*image_width (inches of course) and then use a RasterResampler.
Then send it to the writer.
On the other hand the writer has:
geotiff_tifftag_
resolutionunit
The unit of measurement for
geotiff_tifftag_xresolution
 and
geotiff_tifftag_yresolution
. The possible values are 1, which means that there is no absolute unit of measurement and is usually used for images, 2, which means inches, and 3, which means centimeters.
geotiff_tifftag_
xresolution
Represents the number of pixels per
geotiff_tifftag_resolutionunit
 in the x direction.
geotiff_tifftag_
yresolution
 in the y direction.
 you probably could use these to control dpi (same technique as previously described)
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/geotiff/Feature_Representation.htm
Of course a low dpi input will not improve by upping the dpi.
Forum|alt.badge.img+62
@justinv
geotiff_tifftag_
resolutionunit
 and
geotiff_tifftag_
xresolution
 in the x direction.
geotiff_tifftag_
yresolution
 in the y direction.
To add to what @gio wrote: the dpi value in a TIFF is purely to tell software how big the image will be in print (although graphics software can override it). It has no influence whatsoever on the number of pixels.
  • December 3, 2018
@justinv
geotiff_tifftag_
resolutionunit
 and
geotiff_tifftag_
xresolution
 in the x direction.
geotiff_tifftag_
yresolution
 in the y direction.
@gio @redgeographics
Thank you for the help. That does the trick. I understand that changing the DPI does not change the quality of the image or the print. This was just a requirement to get images through some legacy software that is a bit inflexible.
