Esrishape format
  • November 5, 2013
  • 10 views
I have a doubt, Would it be possible to obtain the name of EsriShape file as an attribute of his reader?
Thanks
  • November 5, 2013
In ESRI Shape format, the format attribute named fme_basename or fme_feature_type will be same as the source file name without extension,  and fme_dataset will be the full path.
You can expose them on the Feature Type Properties dialog box of the reader, or using the AttributeExposer transformer.
Takashi
fmelizard
Forum|alt.badge.img+18
  • November 5, 2013
You can also make use of the FeatureTypeExtractor transformer.
Itay
  • November 9, 2013
Thanks!!!
