Best Answer
Generic Reader - CSV parameters
  • January 13, 2015
  • 34 views
Hello,
When using the Generic Reader and running a CSV file through it, is it possible to specify the CSV parameters somewhere. In the Log file when I run it as is I see:
Opening the GENERIC Reader on dataset `C:\\Temp\\Northgate_Edgbaston.csv'
CSV Reader: Opening CSV files in directory `C:\\Temp/\\'
CSV Reader: Separator Character: ','
CSV Reader: Skip Duplicate Delimiters: no
CSV Reader: Strip Quotes From Fields: no
CSV Reader: File Has Field Names: no
CSV Reader: Field Names Follow Header: no
CSV Reader: Number of Lines to Skip: 0
CSV Reader: Number of Footer Lines to Skip: 0
CSV Reader: Encoding name ''
CSV Reader: Allowing Spaces in Column Names: no
CSV Reader: Max features to scan for schema: 10000
CSV Reader: Opening dataset 'C:\\Temp\\Northgate_Edgbaston.csv'
But I'd like to be able to set these parameters so that I can specify that the CSV file has field names and to strip quotes from fields.
Thank you,
Peter.
Best answer by fmelizard
Hi Peter,
Add a csv reader as a workspace resource, configure the reader's parameters to your liking and voila, the generic reader will use them.
This also applies to the generic writer, but with a dedicated writer of the formats used.
Hope this helps,
Itay
gio
Forum|alt.badge.img+15
  • January 13, 2015
Appearently on the Generic reader not.
But if you use a csv reader for csv, you can do that in the parameter section on the reader.
fmelizard
Forum|alt.badge.img+21
  • January 13, 2015
Hi Peter,
Hope this helps,
Itay
  • January 14, 2015
Thanks for your help, I've added a CSV Reader as Resource and got it to work fine. As it forced you to put a path in for the CSV file I've just put in '.' instead of a dummy file. This seems to be working fine.
