ms excel data manipulation
  • September 8, 2017
  • 18 replies
  • 83 views
I have two sets of tables in an excel sheet. I want to pick each element from one column of one of the tables and try to find a match in another column of the other table. As soon as I find a match, I want to merge the corresponding rows. I was trying to use FeatureMerger but wasn't able to perform the task. Could you please help me out? Thank you
Best answer by fmelizard
Hi @rhlkochar, the FME 2018.0 beta currently available (build 18165) has the ability to read in Excel tables similar to Excel sheets. You can specify to read in the tables as different Feature Types which will allow you to perform the merge using the FeatureMerger.
danilo_fme
Forum|alt.badge.img+52
  • September 8, 2017
Hi @rhlkochar,
I believe the transformer FeatureMerger is good in this case.
The Output port is carry attributes like a list? Have you tried to make the configurations : Attribute Accumulation or Generate List ?
Thanks,
Danilo
  • September 8, 2017
Agree that the FeatureMerger would be the way to go. However, I think that the point here is how to read records from two tables within a single worksheet.
If so, please show us a sample data and what you've done so far concretely, which will help us to understand the issue correctly and consider the right way to resolve your issue.
pratap
Forum|alt.badge.img+12
  • September 11, 2017
I understood that you have 2 excel files and you want to merge rows based on column...
So have you connected to respective ports and provided the settings as below...
one column of one of the tables (Requestor port of Feature Merger)
another column of the other table (Supplier port of Feature Merger)
then you have to select the column names in Feature Merger settings...
If yes then either by Merged port or UnmergedRequestor port you should get features are you getting???
gio
Forum|alt.badge.img+15
records from 2 or more tables in a single worksheet, either on ore more tabs can be controlled by naming the ranges, or referring to starting position for multiple tables on single tab.
Multi tab...seems obvious to me. As would be multiple sheets.
Rest is a vertical lookup. Can be done using featuremerger, llistsearcher, inline querier.
Efficacy woiuld depend on table size and structure.
fmelizard
Forum|alt.badge.img+21
  • September 12, 2017
data.xlsx
Hi everyone,
I am really sorry for the delayed response. Thank you for your replies. I am attaching a sample dataset here for your reference.
Actually I am looking to match column A (ID) with the From Node in Dataset 2. Say I pick up the first ID from column A. If I get a match in the From Mode, I pick up the corresponding rows of both the matches. Then I move on to the second ID, and so on.
Hi everyone,
Just a small clarification with regard to my last post. I actually want to pick up every ID from column A, one at a time, and check with all the From Node IDs and correspondingly pick up all the rows. I had mentioned that I want the check to stop the moment I found a match. However, I want to find all the matches.
Hi everyone,
And FeatureMerger stops after finding one match. Then it picks up the second ID from column A. How can I get around this problem?
Which version of FME are you using? Did the FeatureMerger reject a feature?
And FeatureMerger stops after finding one match. Then it picks up the second ID from column A. How can I get around this problem? . This is in FME workbench 2017.1
Hi everyone,
Perhaps is this the situation similar to yours?
Join On: ID to FROM_NODE
This looks similar. I am understanding the job that AttributeKeeper plays. However, wouldn't FeatureMerger run into the same problems as I mentioned, i.e. stop after finding one match?
Hi everyone,
By default, the rejection would happen when a single Requestor matched two or more Suppliers. However, there aren't duplicate supplier features from your dataset. It could be a potential bug in the FeatureMerger.
As a workaround in the interim, connect a Junction or a Logger to the <Rejected> port.
Hi everyone,
Ah, I found duplicate suppliers! There are two "1229748" FROM_NODEs in the Dataset 2. It wasn't a bug. The FeatureMerger rejects duplicate suppliers by default, even if they don't match any requestor.
If you can ignore the second or later duplicate FROM_NODEs, just set Yes to the Process Duplicate Suppliers parameter.
Hi everyone,
If you need to collect multiple Dataset 2 (FROM_NODE) records matched the same Dataset 1 (ID) record, check the Generate List option in the FeatureMerger to save one or more Dataset 2 features matched the same Dataset 1 into a list attribute.
Thank you so much. I will try your suggestion and get back to you
hi all..
even I am facing the same problem and here is the snapshot of input, output from FME and desire output. and one more if ID does not match it should give for that ID ip1.pngip2.pngoutput-by-featuremarger.pngdesire-output.png
