I am having an issues listing the contents of a google drive folder.
First I receive this warning "
Google Drive: SSL certificate verification failed for host 'www.googleapis.com'. HTTPS connections may not be secure. Disabling verification of SSL certificates. Message: HTTPSConnectionPool(host='www.googleapis.com', port=443): Max retries exceeded with url: /drive/v3/files/14VXm0wlvHZuW9tkS46VAWE1MYeIJpkAP?fields=id%2Cname%2CmimeType%2Csize%2CwebViewLink%2CmodifiedTime%2Cparents&prettyPrint=false (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1051)"
Then the translation continues and I receive this error:"
ile "C:\Program Files\FME\python\requests\models.py", line 940, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url:"
click on the url in the python error and I recieve this message"
{"error":{"errors":[{"domain":"usageLimits","reason":"dailyLimitExceededUnreg","message":"Daily Limit for Unauthenticated Use Exceeded. Continued use requires signup.","extendedHelp":"https://code.google.com/apis/console"}],"code":403,"message":"Daily Limit for Unauthenticated Use Exceeded. Continued use requires signup."}}"So I attempted to set up an api key account which I'm not sure is the right path to be going down. Any input as to how I can get google drive connector to list all my files would be most helpful.
Thanks!
