Data from SAPHanaWriter (spatial) cannot be displayed in ArcGIS Pro
abal
I am trying to translate features from an ESRI File Geodatabase (using the File Geodb reader) to an SAP HANA database using the SAP HANA Spatial Writer.
With the default configuration of the writer, I can access the database and write features which I can properly display in FME Data Inspector. In contrast to that, I cannot display the data in ArcGIS Pro. The following error message appears: "Failed to add data."
In addition, the query layer seems to miss a reference to the table data in ArcCatalog. If I access the DB with a DB visualization tool, the data looks fine. Every feature has a Shape and a GEOM attribute, e.g.
Does somebody have any experiences with this bug/behavior and can provide help so I can display my data in ArcGIS Pro?
I am using the following set-up:
FME Desktop 2018.0 Oracle Edition
Build 18312 - WIN64
ArcGIS Pro 2.1.3
I set up the connection to HANA according to this article:
https://knowledge.safe.com/questions/72129/connecting-to-a-hana-geodatabase.html
Thanks in advance!
Be the first to reply!
