I am having different dataset, that i have to convert to CityGML using ADEs.
When am trying to do this, TRANSLATION WAS SUCCESSFUL is displayed (eg: 780 features transformed)
BUt, when am viewing it in FME Data Inspector, "THERE IS NO GEOMETRY IN THIS VIEW" is shown
I am using FME trail version. LOG TABLE shows this: "The 'FFS' reader was destroyed successfully
Failed to display the table contents due to the following error:
The floating license environment variable LM_LICENSE_FILE is defined, but is ignored by FME. To enable FME to use LM_LICENSE_FILE, set the environment variable FME_USE_LM_ENVIRONMENT to the value YES."
please help me..
