Vertical Reproject HT2_0 to EGM96
I have some points that were acquired with GPS using HT2_0 geoid and WGS84. I need to reproject the elevations so they reference the EGM96 geoid. How can I do this in FME using CSMapReprojector? I've set up a workbench with CDMapReprojector and referenced the .gdc file: C:\\Apps\\FME\\Reproject\\GeoidHeightGrids\\World\\Egm96-Wgs84.gdc
But I get an error:
CsmapReprojector_2(TeeFactory): CsmapReprojector_2: Reproject: Could not reproject the geometry of the preceeding feature: Reprojector: Could not create reprojection engine
My Egm96-Wgs84.gdc file looks like:
# http://cddis.nasa.gov/926/egm96/egm96.html
C:\\Apps\\FME\\Reproject\\GridData\\WW15MGH.GRD
And I do have the WW15MGH.GRD file in that directory.
Be the first to reply!
