I'm trying to connect to an unversioned table that has archiving enabled. I'm using the Esri Geodatabase (ArcSDE Geodb) reader. I connect as the owner of the table, the same user that was used to enable archiving.
In the table list i cannot see the table ending in _evw (the database view containing the archived information), only the feature class itself. Should I be able to see the _evw-table?
I add this Archive Where clause: GDB_FROM_DATE > 20070101090000
When trying to read the features, I get this error message: "Invalid archive where clause. The archive where clause must be in the format 'GDB_FROM_DATE|GDB_TO_DATE <logical operator> <date> [AND GDB_TO_DATE <logical operator> <date>]' and be space delimited."
What am I doing wrong? Are there any other fields I should have filled in? Could the date format be wrong? There are no historical versions or historical markers in the database.
Concerning the view, it will depend on your ArcGIS version and how the view was defined. In general, if it is a regular database view you will have to either register it as a layer in SDE to make it visible in ArcGIS (prior to ArcGIS 10.2 I believe), or you will have to define it as a query layer (starting with ArcGIS 10).
David
I think you have forgotten doubles quotes. The following archived clause should work :
"GDB_FROM_DATE > 20070101090000"
Nicolas
Hi all,
I want to reopen this topic as I encountered an unexpected behaviour in FME 2016. When I use an ArcSDE-Reader and insert e. g. "GDB_FROM_DATE > 20070101090000" (with double quotes) for Archive Where Clause, I get the desired results.
When I use a FeatureReader and input the same feature class and Archive Where Clause, however, I get the following error message:
Does the FeatureReader-Archive Where Clause parameter expect another format and outputs the wrong error message? I have also checked this thread but couldn’t find anything relating to FeatureReader specific adpations.
Best regards,
André
PS: I am using FME 2016.1 (Build 16494).
Hi Folks,
We are looking a new variation of this problem mentioned by @andr_ where the Archive Where Clause is not working when used in the FeatureReader and indeed this is a known issue. In fact the problem is related to original issue posted by @ turid_skedsmo where we noticed you need to use double quotes around the Archive Where Clause. Unfortunately this work-around doesn't work in the FeatureReader. We are looking for a work-around and our developers are looking into this problem but in the meantime apologies for the inconvenience.
Ken
@KenAtSafe : Thanks for the fast response. Do you have, by chance, any information on when this issue may be fixed?
