WFS returning 0 features
  • January 14, 2019
  • 13 replies
  • 212 views
I'm having difficulty accessing data with a WFS reader.
I can read the feature types, and the translation is 'successful', but returns 0 features. I can load the WFS in QGIS too.
I've tried amending various parameters without success, including: connection timeout length, max features, ignore application schema (this worked with the previous version of the WFS), and using a search envelope.
The WFS is: https://environment.data.gov.uk/spatialdata/historic-flood-map/wfs
Would really appreciate if anyone can nudge me in the right direction!
Best answer by david_r
Playing around a bit more I suspect that you will need to constrain the WFS query for it to work; the server times out if you query the layer without any criteria. I suspect the resulting dataset is too big.
You could try either setting "Max features" to some reasonable number, or defining a geographic search envelope. That seems to work fine for me.
  • January 14, 2019
I tried the URL and got the same result. I then looked closely in the FME log and found the following line just under the line where it prints the full URL of the WFS request:
Received HTTP response header: 'HTTP/1.1 504 Gateway Time-out'
Unfortunately this is logged as INFO and not as WARN or ERROR as (I believe) it should, and therefore it's not obvious that there was an error.
Can you check your log and see if you find the same server error in there?
  • January 14, 2019
  • January 15, 2019
Thanks! You're quite right that the dataset is large. This almost did the trick - I can get some features by constraining the max features to read.
I'd used a similar method to query the previous version of the WFS using search envelope coordinates, but that seems to not work this time. According to the capabilities document the data is in EPSG27700 but when I look at the wfs data with other data in that crs it's in completely the wrong place, hence why the bounding box method I'd already tried brought through 0 features. V odd!
  • January 15, 2019
Update - apparently this is a known issue with this particular data, whereby the XY coordinates are inverted on the wfs. More info here if anyone else has come across this.
  • January 15, 2019
It could perhaps be related to differences in how different fields interpret X as either northing or easting. More info here: https://gis.stackexchange.com/a/99862
  • February 18, 2019
Update to this - still having issues unfortunately. Using the WFS reader with the following parameters:
This generates the following GetFeature URL, which seems to be invalid - I can get feature types, but 0 features are read: https://environment.data.gov.uk/spatialdata/historic-flood-map/wfs?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=ms%3AHistoric_Flood_Map&NAMESPACE=xmlns%28ms%3Dhttps%3A%2F%2Fenvironment.data.gov.uk%2Fspatialdata%2Fhistoric-flood-map%2Fwfs%29&BBOX=444018%2C321614%2C489124%2C401169%2Curn%3Aogc%3Adef%3Acrs%3AEPSG%3A%3A27700&MAXFEATURES=30000
I spoke to the data provider and the correct URL should be https://environment.data.gov.uk/spatialdata/historic-flood-map/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAME=Historic_Flood_Map&BBOX=444018,321614,489124,401169,EPSG:27700&srsName=EPSG:27700
This makes sense as it has the parameters for the bounding box CRS, and works as expected (when I use version 1.0.0 instead but that's a separate issue...)
I'm not sure where we're going wrong with the WFS reader. Whilst I can of course generate the URL myself it would be handy to be able to use the WFS reader parameters to do this, so would appreciate it if anyone can give any pointers.
Thanks
itay
Forum|alt.badge.img+18
  • February 18, 2019
In the WFS reader under connection properties you have 2 settings (connection timeout length and transfer timeout length) that help with these kind of issues.
I usually set it up on higher values that the defaults.
Hope this helps.
Itay
  • February 20, 2019
Hope this helps.
Itay
Thanks for the suggestion, we already tried that at the start. It was ultimately a combination of the WFS server timing out because our request was too large, and the WFS Reader generating an invalid GetFeature URL (see comment above) so the bounding box wasn't being recognised.
In the end I built the GetFeature URL from scratch rather than trying to do it with FME parameters. Also my area of interest was still too large so I chopped this up using a gridGenerator, got the coordinates into attributes using a BoundsExtractor, and fed this into a FeatureReader using the min/max XY attributes in the dataset URL.
chrisatsafe
  • March 5, 2019
Hi @katiem,
Have you given this a try in our latest FME 2019.0 beta? There are a few fixes available for the WFS reader available in 2019 which may have resolved this issue. I was able to read 227 features using the parameters you supplied and the URL in FME 2019.0 build 19214:
Hope this helps.
Download the latest FME 2019.0 beta here.
wfs.fmwt
chrisatsafe
  • March 5, 2019
Thanks
Hi @katiem,
Hope this helps.
wfs.fmwt
danilo_fme
Forum|alt.badge.img+52
  • March 5, 2019
Hi @katiem,
Hope this helps.
wfs.fmwt
Hi @ChrisAtSafe
Thanks to inform us about this .
Danilo
  • September 26, 2019
In FME2018.1 and 2019.1, I'm confused about reading WFS from environment.data.gov.uk.
FAQ's at environment.data.gov.uk give the following as an example GetFeature:-
I get/receive features with my WFS READER configured as follows, with a BBOX in LatLong coords :-
CRS=EPSG:27700/WFS=1.1.0/AxisOrder=2,1/max=5/bbox=51.4937388139627714/-0.3969194790841968/51.3866329950004612/-0.1233058624383356/BBOXCRS=bob
That's okay.
Note the order of the bbox coords, Latitute then Long, to match AXIS ORDER 2,1.
Sadly, FME2018.1 and 2019.1 fails to get any features if I use OSGB/Brit National Grid/EPSG27700 coords in my BBOX:- CRS=27700/WFS=1.1.0/AxisOrder=2,1/max=5/bbox=510500 165500 524500 179500/BBOXCRS=EPSG:27700
As a town council, we work in OSGB/Brit National Grid/EPSG27700 coords.
Also, I'm confused that FME seems a) to not include "&srsName=EPSG:27700" in the GetFeatures requests??
b) FME does suffix "EPSG:27700" to the BBOX cords, even though I set SEARCH ENVELOPE CRS to i) Mr Bean ii) LL-WGS84 or iii) any random string
In FME2019.1, I set "SEARCH ENVELOPE CRS" = mr bean
FME2019.1 log says:-
Sending HTTP 'GET' request to
https://environment.data.gov.uk:443/spatialdata/sites-of-special-scientific-interest-units-england/wfs?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=ms%3ASites_of_Special_Scientific_Interest_Units_England&NAMESPACE=xmlns%28ms%3Dhttps%3A%2F%2Fenvironment.data.gov.uk%2Fspatialdata%2Fsites-of-special-scientific-interest-units-england%2Fwfs%29&BBOX=-0.3969194790841968%2C51.38663299500046%2C-0.1233058624383356%2C51.49373881396277%2Curn%3Aogc%3Adef%3Acrs%3AEPSG%3A%3A27700&MAXFEATURES=5'
waiting for response ...
It gets 31 records/features. That's okay.
Part of the BBOX parameters includes:-%2Curn%3Aogc%3Adef%3Acrs%3AEPSG%3A%3A27700 ie urn ogc def crs EPSG 27700
It will get/receive features if, I use the bbox coords in Lat Long format. That's okay.
FME gets zero features if my bbox coords are in EPSG27700. Not okay.
I set "SEARCH ENVELOPE CRS" = LL-WGS84
'https://environment.data.gov.uk:443/spatialdata/sites-of-special-scientific-interest-units-england/wfs?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=ms%3ASites_of_Special_Scientific_Interest_Units_England&NAMESPACE=xmlns%28ms%3Dhttps%3A%2F%2Fenvironment.data.gov.uk%2Fspatialdata%2Fsites-of-special-scientific-interest-units-england%2Fwfs%29&BBOX=-5599806.778056016%2C7442159.613065494%2C-5549611.459638113%2C7462169.2105717445%2Curn%3Aogc%3Adef%3Acrs%3AEPSG%3A%3A27700&MAXFEATURES=5', waiting for response ... Again, FME gets zero features.
@david_r @chrisatsafe @katiem
I can imagine lots of council staff in the UK spending loads of time trying and failing to connect their FME to environment.data.gov.uk
Attached are my workbenchs.
..Lat Long Coords.. works,
..27700 corods.. don't work.
CLIP TO SEARCH ENVELOPE
As I said in my previous reply, below here..
For https://environment.data.gov.uk/spatialdata/historic-flood-map/wfs?
That's okay.
But, if I simply tick/check CLIP TO SEARCH ENVELOPE with above settings, I get zero features. Not okay.
This is a pain because some of the floodzones are massive.
So, I need to clip them to my bounding box.
