-2147024894 error when importing reader, file geodatabase
I cannot import a file geodatabase into FME 2014. I am using ArcGIS 10.1. I checked with the data provider and they are on the same version. Also the file geotabase does open in ArcGIS but not FME. Anyone know why this may be.
Best answer by ryan
Hello KDMUR,
Is the file geodatabase compressed or zipped? That can cause this type of message in FME.
Regards,
Ryan Cragg
