Hey everybody,
recently I'm getting into converting 2d autocad plans into a simplified 3d model. So far I'm able to create a model. Now i have checked the tutorial of @daveatsafe in converting a dwg to ifc with rooms but I'm still having a question.
How do I write the autocad layer property to an ifc file that I use in BIM dwg. Because at this moment whatever I'm trying I'm getting all the entities on layer 0.
Thanks in advance,
Andreas
