DXF / DWG writer define $INSUNITS on 6 like (m)
  • June 21, 2017
  • 36 views
How can I define the Export Parameter
$INSUNITS
Without Settings the Export to dxf is:
$INSUNITS
70
1
9
the second number must be Change to 6
mark2atsafe
Forum|alt.badge.img+59
Hi @dirk1964
Check the writer parameters. There should be a parameter called Insertion Scale Units. Change this to METERS and you will get the result you want:
$INSUNITS
70
6
9
Here's a short movie demo: https://www.screencast.com/t/n3HvWk68OLlB
Regards
Mark
  • June 22, 2017
Thanks, well done.
