How to expose source length unit from IFC file?
  • February 14, 2020
  • 174 views
I've got a scaler in my workbench, however I would like to use a tester transformer, and branch based on source IFC file units which are either millimeter or meter. Currently I cannot batch input as we are relying on the reader and the unit expression feedback from visual preview. If the visual preview can work this out - surely there is an attribute we can expose?
Any help appreciated.
Many thanks
daveatsafe
Forum|alt.badge.img+20
  • February 14, 2020
Hi @jacobbuckley,
If it is not already exposed, you can use the AttributeExposer to expose the lengthunit attribute on the source IFC features.
  • February 24, 2020
Hi @jacobbuckley,
Hi Dave,
Thanks for your response. I have found that Lengthunit is not accurately describing units used when creating the IFC file. For instance on several recent files the actual unit is millimeter (as confirmed on visual preview), while lengthunit is displayed as metre. Could this be a default attribute?
Thanks
daveatsafe
  • February 24, 2020
Hi Dave,
Thanks
Hi @jacobbuckley,
Would you mind sending a copy of the IFC to so we can create a problem report for our development team about the lengthunit?
You may find the FME Hub transformer https://hub.safe.com/publishers/bleuminkgeo/transformers/coordinatesystemmapunitextractor useful, to get the length unit from the coordinate system.
  • June 22, 2021
Hi Dave @daveatsafe​ ,
I'm facing the almost same question as Jacob. Need to identify the units of input IFC firstly, and decide which conversion process to go. Also, the attribute of LengthUnit seems not complete for the input IFC.
I've tried the transformer: CoordinateSystemMapUnitExtractor for two IFC files, the results varied. It works fine for the IFC generated from Revit, an attribute called _units was created containing the correct units information (mm); however, for the IFC generated from Civil 3D, it seems the transformer didn't work.
I uploaded two of the IFC data here for your review: https://we.tl/t-BGoInZAlfv. Thanks in advance!
