Zip files reading error on FME Server
  • November 27, 2019
  • 15 views
Encountering issues while reading FGDB from .zip files stored under resource folder:-
"Unable to connect to File geodatabase. Please make sure the correct file name was specified..."
Hi @shreya61094,
I'm sorry that you are encountering this issue. We are aware there have been some intermittent problems reading zipped FGDB in FME Server and are currently investigating the cause (FMESERVER-13382). To help us with our investigation please could you provide some further information:
  • What build of FME Server are you are using?
  • Does the failure occur every time or randomly for the same file?
  • Does the failure occur for just a single file or any FGDB you try?
  • A copy of the job log and the problem gdb.
As a workaround please consider modifying your workspace to include a Creator > Unzipper > FeatureReader instead of the Reader to unzip the files first before reading them in.
