I'am creating a workbench which uses a MSSQL database writer to delete certain records from a database. In most cases this works fine but sometimes I get the following error/Warning message:
MS SQL Server Writer: Failed to write a feature of type <name of the table> to the database. Provider error `(-2147217871) Query timeout expired'. SQL Command `DELETE FROM <name of the table> WHERE <field within the table> = 6339404'
Every time this error occurs there are exactly 50 seconds between opening and closing the database connection. In case the workbench runs without error the connections lasts shorter and is executed without any problem.
The following changes did not solve the problem:
- Change Command Timeout from 30s to 600s and even to 9000s (when executed directly in SQL server management studio the query takes about 1 minutes and 30 seconds to execute, so 600s should be more than enough).
- Checked the time out settings of SQL server. They are set at default which is about 10minutes.
Is someone able to tell me how to solve this problem? Or give me any advice on how to solve it?
