looking to write in pdf file a polygon with a raster image clipped to. they will be 2 views one closer view and second with fare view
Any suggestions
I manage to create a WS ( staticmap-to-pdf.fmwt), using imageFetcher transformer, the only problem is the PDF is writing only, the image, not the vector
Actually your geometry is projected above the image raster...very tiny.
You see 2 objects entering the pdf-writer the raster and the geometry.
If you put the geometry in a separate input on the PDF-Formatter, align (using a affiner and the center points) them and give them the same page object size the geometry will be bigger. But not the same size still.
But the map api automatically sets a margin so more work is needed to get them to align exactly.
