Is there a way to add an additional value to absolute value in the KMLPropertySetter Parameters?
  • June 2, 2017
  • 28 views
For example, I would like to add 40 meters to the current absolute value height.
Best answer by jdh
You can use an offsetter on your features to add 40m to the Z value.
jdh
Forum|alt.badge.img+40
  • June 2, 2017
  • June 5, 2017
Terrific, thank you jdh. Your solution worked perfectly!
