Hello all,
I am trying to add one UUID for each CAD file entering the workbench. Is there a way to set a parameter so when a new filename enters the workbench, each feature with the same filename receives the same UUID character? I have tried using a the filenameextractor followed by the attributecreator and using the @uuid() function as the new attribute value. But that just gives each feature a different UUID instead of the same. Any assistance would be appreciated.
Thanks,
David
