Read coordinates from Microstation V8 file
I have a set of microsation v8 files. The files have a coordinate system attached to them. When I use FME to read in and output file to a different format (such as shape files), the readouts now show that everything has been shrunk to within fractions of a seconds of the origins of the file, instead of being in their true geographic location. Is there anyway to get FME to correctly read the coordinates so my output data is in the correct location?
