File Copy - DELETE
  • May 19, 2015
  • 15 replies
  • 2332 views
sigtill
Forum|alt.badge.img+25
Is it possible to DELETE files using the WRITER "File Copy" ?
UPDATE:
I have created a custom transformer that uses the solution (FeatureWriter in MOVE to null) and uploaded to https://hub.safe.com/publishers/sigtill/transformers/filedeleter
Feel free to send any feedback related to this.
Best answer by sigtill
UPDATE: 2020:
This solution seems to be easier than the previous:
Replace the three variables needed (filecopy_XXX, XXX XXX) and the dest_filename to nul (with one l, not two ll). And make sure the FeatureWriter is set to MOVE
  • May 19, 2015
Hi Sig,
I don't think it's possible, but it's easy to delete a file with a script. Assuming that an attribute called "filepath" stores the file path that should be deleted,
# Example for PythonCaller
import os
def removeFile(feature):
    file = feature.getAttribute('filepath')
    if os.path.exists(file):
        os.remove(file)
# Example for TclCaller
proc delFile {} {
    file delete [FME_GetAttribute "filepath"]
Takashi
  • August 25, 2016
Hi Sig,
import os
        os.remove(file)
proc delFile {} {
Takashi
@takashi How would you write this script to delete entire folders instead of files?
itay
Forum|alt.badge.img+18
  • August 25, 2016
@kam you could just use a system caller and an old fashion dos command for that
  • August 26, 2016
Hi @kam, the "os.rmdir(path)" method removes an empty folder; the "os.removedirs(path)" method removes a folder and its subfolders recursively if they all are empty; the "shutil.rmtree(path)" method removes a folder and all files and subfolders belonging to the specified folder. See the Python documentation to learn more.
mark2atsafe
Forum|alt.badge.img+59
  • August 26, 2016
You could use FileCopy and move the file to the null folder. \\dev\\null on Linux I think. There is a Windows equivalent, but I can't recall it off hand.
sigtill
  • October 15, 2019
UPDATE: 2020:
sigtill
  • January 14, 2020
The most recent (and best solution) is to overwrite the 3 parameters: and set filecopy_dest_filename = nul (with one l, not 2 ll).
sigtill
  • January 14, 2020
keoe
  • September 21, 2020
Is there anyone that have used FileDeleter from @Sigbjørn Herstad​ on FME Server? For me it works fine in Workbench but not on FME Server. The log files gives the same message but the file isn't deleted when running on the server. Both desktop and server runs on Windows OS. The server write to this files hare so there might not be an permission issue.
Log file:
2020-09-21 11:42:35| 0.7| 0.0|ERROR |File Copy Writer: Cannot create destination folder '\\'
2020-09-21 11:42:35| 0.7| 0.0|INFORM|File Copy Writer: Received move request from '\\\\fileshare1\\folder\\temp\\781af574-ea39-44f9-95d4-ea7f62e050fd.ffs' to 'c:\\temp\\\\\\nul'
sigtill
Log file:
Unfortunately it does not work on FME Server. I would suggest to use a FeatureWriter and Move files to the $FME_SHAREDRESOURCE_TEMP folder. Then they will be deleted by FME Server in a given interval.
keoe
Thank you for your support!
teason
Participant
  • Participant
  • October 1, 2020
Does this support using the fme_dataset attribute as the file to delete? Also, is it possible to put it after a FeatureWriter so basically I can delete the file after it has been processed?
Thanks.
klingdom
  • December 11, 2020
Hello, Can We use *.* with FileDeleter? If not that would be a suggestion for enhancement.
tim_wood
Forum|alt.badge.img+8
  • September 12, 2022
UPDATE: 2020:
I have been trying to use this method but it's not working. However I notice that you are setting a value for filecopy_dest_dataset although there is nothing in the Attribute Value. So are you setting the value to an empty string? I've been using a FeatureWriter to try and do this for *.png in a particular folder, and only specifying the values for filecopy_source_dataset and filecopy_dest_filename.
Or do I need to change some of these parameters?
File Copy Parameters
Forum|alt.badge.img+46
I've not tried the nul method, i normally use a TempPathName creator, move the file to that location and then it's automatically deleted when the workspace completes. This way it works on both desktop and server
