Composite Test AND OR order in TestFilter
  • May 31, 2017
  • 6 replies
  • 25 views
I am using the TestFilter with a composite test set up. However, the results are not what I am expecting. I believe it is something to do with my use of brackets and the AND and OR operator order.
I can't get the following composite test to work:
(1 OR 2 OR 3) AND (4 OR 5 OR 6)
Can anyone explain the order of precedence for OR and AND in the TestFilter composite test and whether the brackets are even recognised?
Thanks
  • May 31, 2017
Can you show a screen shot of your setup?
As it is, it looks like you're trying to test for an attribute having two different values simultaneously.
  • May 31, 2017
Hi David,
Screen shot is below.
I'm trying to find all instances where LINE is equal to 1 or 2 or 3 AND COLOUR = PINK or BLUE or GREEN.
Examples which I would like to find include;
LINE = 1 and COLOUR = BLUE
LINE = 3 and COLOUR = PINK,
etc
Thanks,
  • May 31, 2017
Sorry forgot the screen grab:
lottegis
  • May 31, 2017
For BLUE, is the value supposed to be checked for NOT-BLUE? It looks like any value you're going to test for COLOUR is going to pass except for the actual BLUE value.
  • May 31, 2017
sorry the BLUE is not mean to be ticked - that is a mistake.
  • June 1, 2017
I just created a Tester with a similar setup and it worked as expected (FME 2017.0). Could you perhaps upload a small workspace here that demonstrates the issue?
