How to geocode with FME
Can anyone give me a "How to" or an example workbench on geocodeing within FME. For example I have an excell spreadsheet, lets assume all the address are good and are in a single field and have information like state and zipcode. I want to add that spreadsheet as a reader, geocode the address and write out a shapfile. How do I do it? I don't really care which geocodeing service we use. I saw this covered briefly on the world tour and am curious. Many thanks.
Best answer by david_r
to get you started, here is a step-by-step example using the Yahoo geocoder and her is an article on how to use the Gisgraphy webservices (Geonames and OSM).
There is also a dedicated transformer to access a commercial geocoding service called Proxix.
David
