AttributeManager - expected behaviour?
  • July 4, 2016
  • 5 replies
  • 29 views
Forum|alt.badge.img+46
I'm trying to use the AttributeManager to rename an attribute and at the same time set a value using a conditional formula. Should this be possible?
davideagle
Forum|alt.badge.img+22
  • July 4, 2016
Do you mean like this?attributemanager.fmw
  • July 4, 2016
No, I want to set a conditional value on the attribute I'm renaming
Hi @egomm
it looks like AttributeManager deals with renaming first and by the time it needs to evaluate @Value(_creation_instance) = 0 there is no _creation_instance attribute. I have filed a PR asking to investigate if AttributeManager behaviour can be improved. For now, I would like to suggest
  • calculating the value and assigning it to the new attribute first and then
  • removing the old attribute,
i.e. two steps/lines in AttributeManager.
  • July 5, 2016
Hi @egomm
I managed it in a similar way by setting the value of the original attribute first and then renaming it in a later step.
Forum|alt.badge.img+3
Hi @egomm
I figured this was the reason. But if I try to use the new name for the attribute (e. g. "Order" instead of "_creation_instance") when setting up the conditional values, I cannot get an attribute with the new name ("Order"), only an attribute with the old name ("_creation_instance"). (I use FME 2016.1 build 16609, by the way).
