keep file names the same in the writer as they are in the reader:
Easy...1259 .000 files to be written to 1259 .geojason files. I want to keep the file names the same (with the extension changed naturally). So file1.000 becomes file1.json etc etc.
Best answer by itay
Hi @jhawks,
Have a look at the fme feature attributes fme_feature_type or fme_basename.
You can use them in the writer fanout.
Hope this helps,
Itay
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
