Run part of FME Workspace based on day of the week or if date = X
  • December 4, 2018
  • 170 views
dmerrick
I am trying to set up within an FME workspace a way to run select transformers within the workspace based on the day of the week, and other parts based on the month.
I have various external datasets I want to refresh internally (SDE) by pulling them externally; some datasets are to be pulled every Tuesday, while others are on a quarterly basis (2/1,5/1,8/1,11/1). I would be running the workspace from FME server on a daily basis but have the coding within the workspace to refresh based on preset conditions.
I am running FME 2018.1 build 18547
Best answer by daveatsafe
Hi @dmerrick,
You can do this with a few transformers:
  • DateTimeStamper to generate a datestamp on each feature
  • DateTimeConverters to convert the datestamp to day of week (%w) and day of month (%e)
  • Testers to test if day of week == 2 (Tuesday) or day of month == 1
Hi @dmerrick
You could create an attribute using python that would be able to tell you the day of the week as an integer (0=Monday...) and then use a TestFilter to route the features depending on what you want to do.
To do this, I set the PythonCaller up like this:
daveatsafe
Forum|alt.badge.img+20
  • December 5, 2018
Hi @dmerrick,
dmerrick
  • March 3, 2020
as a follow up/expand upon @daveatsafe comment. To create Quarterly/Annual filter within a workspace that runs only during the week use a testfilter to filter to the first day of the week (Monday = 1) and then the day (Day<=7), then add another testfilter for select months. This allows for a workspace on FME Server running M-F to "catch" quarterly events on weekends (2/1/2020, 3/1/2020 etc) to be run on the first Monday of the month as a workaround.
