problem with sql server geography data type
  • November 2, 2014
  • 0 replies
  • 22 views
Hello
I am trying to load data from a csv file into a sql server db. I have used the VertexCreater transformer to create a point.  When I write this to my sql server db table using geometry data type, everything works great, when I try to write as a geography data type. FME says it succesfully wrote the features but the resulting table is empty. Any insight would be apperciated.
