I am using FME 2018.1 32-bit and while reading an .accdb file, I am encountering this error "WARN |Microsoft Access Reader: The epoch time is out of range. Please ensure it is specified in seconds, and not in milliseconds or microseconds". Translation stops after this with a Fatal Error message. There are more than 2.5 million records in the table i am accessing. If I give a where condition an extract 100 odd records, it does execute. When i run the same Workbench in FME 2017.0 32-bit without any WHERE condition, it executes successfully. Any info on how can i troubleshoot this error ?
Epoch time is out if range
Best answer by chrisatsafe
Hi @bb,
Are you able to re-run the workspace with debugging turned on (Tools > FME Options > Translation > Log Message Filter > Select Log Debug). After running the workspace with debugging on, can you please upload the translation log?
It's tough to say without seeing the log first, but this may be related to a similar issue that is currently being looked into where the translation in FME 2018.1 is failing due to a bad feature or invalid date being read in from an Access Database. This is likely why you are able to read the first 100 features (other tables are likely unaffected by this).
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
