One column has 4 values 2, 12 324, 56987 (data type is number)
When I use filter in Inspector (Table View) to find records with value 2 I got 3 results (2, 12 and 324)
Earlier versions of Fme gave me just one result: 2.
Is it a method to find just records with value 2?
Thanks in advantage:)
Best answer by fmelizard
Hi @elzbietalekve which version were you using previously? I tried FME 2014 and found the same behaviour as FME 2017. I tested both filter methods @danilo_fme showed below. Here is an idea which you can vote on which is asking for what you are expecting: https://knowledge.safe.com/idea/20165/add-filter-function-to-the-table-view-in-fme-data.html (I have also voted on it as I think this would be pretty handy :-D). At this point the only workaround I can think of if using a Tester in a Workspace which is a little impractical
But I want that in Table view I could see just records with the value 2. When I have 50 000 records in my base and I want to find just 2 of them so I will see just 2. oadminelaantall-teigansw-danilo.pdf
I tried the earlier version of FME and I saw that Filter works in the same way. Then it's dawned on me that I most of the time used an unik number in my data. So I am really sorry for misleading
information to both of you (danilo_fme and MattAtSafe) . But I think that is good idea that Filter sholud work as I suggested and will vote for this kind of solution. Thanks very much for Your help:)
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
