Does FME's scripting syntax have a formal name, and where is its documentation?
  • May 9, 2014
  • 15 views
makt
At the bottom of this (https://safecommunity.force.com/CommunityAnswers?id=906a0000000cg4JAAQ&v1=907a0000000cZZVAA2&v2=Up&#!/feedtype=SINGLE_QUESTION_DETAIL&dc=FME_Desktop&criteria=ALLQUESTIONS&id=906a0000000d05pAAA)page, Takashi commented that expressions written into FME translators have an FME specific syntax.
The syntax does seem very straightforward, but I was looking to see if there are some useful, more advanced features about it that I have not come across. I tried to find out more details about the syntax, but with no luck; I don't know what to call it when searching.
Is there full documentation to this syntax?
Does it have a more formal name than "FME syntax"?
Best answer by takashi
# re-post. removed previous post for failure to paste URL links.
I've never seen a documentation fitting to your requirement exactly.
I frequently see these links:
http://docs.safe.com/fme/html/FME_Workbench/Default.htm#transformer_parameters/arithmetic_editor.htm
http://docs.safe.com/fme/html/FME_Workbench/Default.htm#transformer_parameters/advanced_text_editor.htm
http://docs.safe.com/fme/html/FME_Workbench/Default.htm#transformer_parameters/expressionevaluator.htm
http://docs.safe.com/fme/html/FME_Workbench/Default.htm#transformer_parameters/Feature_Functions.htm
http://docs.safe.com/fme/html/FME_Transformers/Default.htm#transformer_parameters/StringFunctions.htm
FYI,
Takashi
  • May 10, 2014
