{@getFileName(@zip(OutputLocation))} doesn't work in linux web app
  • September 17, 2014
  • 35 views
raphael
Participant
Hello,
My core runs on a windows server. My Fmeserver web app runs on linus server.
For a sync datadowload service, I get my result with the correct URL and a good zip file. But wth the same wkb in async, I receive an email but tne URL is bad, I beleive {@getFileName(@zip(OutputLocation))} doesn't work.
Has anybody he already had the problem
Thank you
Raphael
  • September 18, 2014
Hi Raphael
Can you please tell us what build of FME Server are you using? I just tried it with FME Server 2014 SP2 - Build 14338 - linux-x64 and it seemed to work.
Does the webapp use a POST or a GET?  Maybe you could show us the code you use to send the request.
And it might help to show a screen capture of the email subscription DataDownload_Email_JobSuccess. I guess you could hide the account name etc.
Thanks
Ken
raphael
Participant
  • Participant
  • September 19, 2014
Hi Ken,
The build is older than your FME server. The build is  FME Server 2013 SP4 - Build 13547 - linux-x64.
My tests were just with the FMEserver Webui with the option "send by mail" for the async and without the option for the sync. I have not tested a rest call.
Raphael
  • September 22, 2014
Hi Raphael
I'm going to move this to support. It may be an issue with proxy server -are you doing that?
Thanks
Ken
Actually I think I know the problem. Can you please try this procedure:
http://screencast.com/t/SeVdxz6CL
