Transalation using fme desktop 2012 on Windows 7 oracle client 11.2.0 x64
  • November 19, 2013
  • 18 views
Transalation using Fme desktop 2012 fails error  - Oracle client libraries could not be loaded. Ensure the client is installed and properly configured. Check the System path Environment Varialble.
The Path variable seems to be ok - the Client can connect to the Oracle database - Some issue between the Application and version of Oracle installed.
  • November 19, 2013
One possible reason of the erro is the difference of bit-version between FME and Oracle Client. There is a related article: Oracle clients for FME running on a 64 bit OS http://fmepedia.safe.com/articles/FAQ/Oracle-clients-for-FME-running-on-a-64-bit-OS
Takashi
  • November 19, 2013
If you're using the Oracle Instant Client, be sure to read this article.
My experience is that the full Oracle client install is the easiest to work with, though.
David
