[FME 2011] String padder doesn't work
  • June 27, 2013
  • 37 views
Hi folks,
I have a simple workbench taking an ArcSDE spatial table as input. In this table, I have a string field I want to fill with 2 digits. This field already has values, but a lot of them are only coded on 1 digits (1,Z,a...).
I thought of insert a left pad and replace this pad with a digit of my choice (0 or Z) to make my field homogeneous.
But the StringPadder doesn't work... :-( At now, I don't have a writer, I'm only working with visualizer to see the potential result, and it's always wrong, I mean values still have the same length.
Does it make sense ? Any idea ?
Thanks a lot,
François
Best answer by takashi
Hi Francois,
I cannot reproduce your situation, the StringPadder of FME 2013 works successfully. If the StringPadder does not work anyway, try the StringFormatter instead.
Takashi
  • June 27, 2013
Hi Francois,
Takashi
  • June 27, 2013
Hi Takashi,
Thanks a lot for the trick. It worked !
Cheers,
françois
